I was wondering if it is possible to use some of the different software synthesizers with virtual dj 8. I know you can download the different effects from virtual dj but these seem to be one shot type effects that you have no control over. I want to be able to twist the knobs etc. to get my own effects more like a virtual moog synthesizer, etc. I know if you use abelton, which I do not, then you can use all kinds of plugins for effects. I use a PC by the way.
Thanks,
Steve
Thanks,
Steve
geposted Tue 17 Jun 14 @ 5:54 pm
I had tried some vst synths in vdj7 ...couldnt reroute audio through it properly but kinda worked.there is one software that came with a controller that might work.but I need to get it first..
geposted Wed 18 Jun 14 @ 7:58 pm
VSTs some work some don't I've had 1 or 2 that had a keyboard gui and they made noise
http://www.vst4free.com/free_vst.php?id=1737 is a fun start
geposted Wed 18 Jun 14 @ 8:55 pm
with vdj7 you have to play something on a deck where you have the synth opened.the synth then uses that track as an ocillator.kinda wierd.but that was vdj7.
geposted Thu 19 Jun 14 @ 1:02 am
I'd hazard a guess that VDJ just isn't "wired" to host VSTi (instrument) plugins.
Remember, VDJ is DJ software - not a DAW. The ability to use VST plugins is there for effect purposes, for audio from the decks to pass through.
VSTi plugins need a MIDI input in order to be played via a keyboard, sequencer etc. and VDJ isn't designed that way.
VDJ can be linked to full blown DAWs via ReWire though, but it has to be the master.
geposted Thu 19 Jun 14 @ 5:18 am
I guess we be asking too much lol...
geposted Thu 19 Jun 14 @ 6:06 am
