Ver. 7;
If a track is playing and you try to load another track on the same deck, a popup appears that says 'a song is playing on this deck. Are you sure you want to stop it? (yes or no)'
How can I map a keyboard key to enable a yes or no answer?
Thanks in advance.
Thanks in advance.
geposted Wed 18 Jun 14 @ 1:41 pm
with TAB you cycle the selection through Yes and No. With ENTER you make you apply your choice
geposted Wed 18 Jun 14 @ 2:26 pm
Version 7 you can use escape [Esc] for cancel and enter for yes.
geposted Wed 18 Jun 14 @ 3:52 pm
