Hi,
I downloaded the AnSpec Equalizer from http://www.voxengo.com/product/anspec/
Then put the DLL file in MyDocs/VirtualDJ/Plugins/Other
When I goto the Master Tab in VDJ, and select that as a Plugin, I get the error that it isn't compatible.
I tried both 32 and 64 bit.
Any ideas?
Any ideas?
geposted Thu 19 Jun 14 @ 8:45 am
You need 32 bit - tested it here on W7 64 bit and it's working without issues.
geposted Thu 19 Jun 14 @ 8:48 am
Also it's a VST and thus a SoundEffect, would be sensible to install in the SoundEffect folder.
geposted Thu 19 Jun 14 @ 8:50 am
Got it, stupid me forgot to delete the 64bit from a different folder.
geposted Thu 19 Jun 14 @ 8:57 am
It's not an effect Scott (it doesn't change the sound in any way). It's just a meter / RTA.
I've got mine in Other and it works OK.
audiotech520, can you be a bit more specific about exactly what the error message says? It is literally just "not compatible"?
geposted Thu 19 Jun 14 @ 8:59 am
He solved it; user error.
geposted Thu 19 Jun 14 @ 12:18 pm
hmm,thats odd.he calls it an equalizer,I would think it goes under sound effects,not "other"...
geposted Thu 19 Jun 14 @ 3:20 pm
It isn't a EQ it's a analysiser
geposted Thu 19 Jun 14 @ 3:26 pm
yeah I got that,loco...
geposted Thu 19 Jun 14 @ 4:31 pm
