Topic: Desktop laptop sync
Is it possible to sync vdj from my desktop to my gig laptop so if i make change with my desktop VDJ Like tagging and rating, played ect. its reflected on my gig laptop cause i do a lot of editing and other things on the desktop. Do I have to repeat those things.
Edit: Okay i have FreeFileSync now..What folders CANNOT be sync together, That might cause software or database errors because certain things wont match
geposted Mon 23 Jun 14 @ 10:27 pm
Have you tried the total commander tool. i know some users working with that program (no freeware unfortunately). but to be honest, no feedback how it works with V8 database...;-)
http://www.ghisler.com/
Ive been using bitorrent sync for over a year, and I have had no problems. As long as the folder paths for the mp3's are the same on both systems everything should sync.
