I'm getting all messed up with my music collection which is stored & backed up in so many places its starting to confuse me !
I thinking if I just put it all on a high capacity portable drive and then swapped it over to what ever computer I'm using at the time, then the VDJ database will in theory be the same (all the cue points, tag edits etc etc ).
does this sound feasible?
geposted Tue 24 Jun 14 @ 5:49 pm
Yep feasible, just copy on to the external in VDJ and the database will carry over.
geposted Tue 24 Jun 14 @ 8:34 pm
Not only in theory also in practical use, cause the db with all the informations is stored on the external also. This happens also to e.g. Virtual Folders you have created using your ext. hdd.
greetz
rob
greetz
rob
geposted Wed 25 Jun 14 @ 4:33 am
To copy Filter/Virtual Folders you also need to make a copy of the VirtualDJ folder in the root of your device.
Greets, Heiko
Greets, Heiko
geposted Wed 25 Jun 14 @ 4:48 am
Gtreat - many thanks guys
geposted Wed 25 Jun 14 @ 5:37 am
Can I just confirm you mean the main VirtualDJ folder in my documents that contains all the sub folders & files - Skins, plugins etc etc ?
geposted Thu 26 Jun 14 @ 4:00 am
On the main disc it's called: \Documents\VirtualDJ\Folders\
I think on external devices it is \VirtualDJ
Greets, Heiko
Greets, Heiko
geposted Thu 26 Jun 14 @ 6:25 am
all understood - many thanks guys
geposted Thu 26 Jun 14 @ 6:34 am
@ jakovski
You do mean copy the VDJ folders to the external from within VDJ?
I'm surprised that works, how does it know the new file path? I shall have to give this a test..
geposted Thu 26 Jun 14 @ 6:54 am
