Topic: Gate Effect
I'm still looking for A good Gate effect to use with VDJ8 like I have In VDJ7 "Gates_TexZK".
I understand that the VDJ Group is not "Building" Effects but as I said I'm looking for a solution.
I wont move to v8 until I have all the effect's I use daily...
Any suggestions?
do you know a good gate effect that will work with VDJ8 (Maybe a VST)?
thanks
geposted Thu 26 Jun 14 @ 4:13 pm
I like this one, it's simple and effective ( & free), every bit is mappable but VDJ doesn't save the settings between sessions so you have to set the dials either ONINT or when triggered (the sync length is slider 11)
You are best off avoiding the random button in doesn't really sound good.
http://www.tweakbench.com/cairo
effect_active 'tb_cairo_1_4' & effect_slider 'tb_cairo_1_4' 11 0.8
this is set to 1/2
0.5 = 1/8
0.6 = 1/4
0.7 = 1/3
0.8 = 1/2
0.9 = 1
1 = 2 but the gui doesn't show that but it is free
If you end up using it often consider donating something to the developer.
Nice, but not the best interface and mapping.
as for the money... believe me I'm willing to pay for a good effect.
if TexZK will modify he's gates plugin I will be happy to pay.
any more suggestions?
it does and it doesn't mate you can't import patterns or save them in VDJ so other that setting it all up and never turning off VDJ ever, it's a random one trick pony, a bloody good one but not good for planned actions .
Oh hang on are we talking glitch or glitch2? I'm talking 2
