So i picked up a lpd8 for 25 bucks just for samples and couple other random things. Pretty cool and easy to map. Only thing now i want is to have the led stay on while the sample is playing? Anyone done this or is it even possible. I was thinking writting: blink '300rms or whatever' active on at the end of the command sample play 1 play_stop. Yet i haven't tried this, just saw this on a post about a map for an effect . Anyone? Please and thanks
geposted Thu 26 Jun 14 @ 11:08 pm
Hi,
which version of irtual DJ are you using exactely ? Cause the LE one you registered does not support any external MIDI controllers and mapping.
Greets, Heiko
Greets, Heiko
geposted Fri 27 Jun 14 @ 12:52 am
