Does anyone know how to access or transfer history from VDJ7 to VDJ8? Thanks in advance.
geposted Sun 29 Jun 14 @ 3:14 am
Should be automatic when installing, but if not copy the contents of the tracklisting folder (MyDocuments/VirtualDJ) and put it all into the Hostory folder in the same directory.
geposted Sun 29 Jun 14 @ 4:52 am
Thanks but when I open virtual DJ history it's only showing me VDJ8 and can't find VDJ7 history to copy over?
geposted Sun 29 Jun 14 @ 6:00 am
Close virtual DJ.
Open windows explorer, navigate to MyDocument/VirtualDJ then follow the above instructions.
geposted Sun 29 Jun 14 @ 7:11 am
That's where I was looking ;)
The only history in the documents folder is for VDJ8 - can't locate the history folder for VDJ7?
Thanks for your patience on this.
geposted Sun 29 Jun 14 @ 7:51 am
geposted Sun 29 Jun 14 @ 9:15 am
All sorted thank you :)
geposted Mon 30 Jun 14 @ 2:22 pm
I wanted to know if there is anyway to stream a live video mix, or if anyone knows of any program that could do it???
geposted Tue 01 Jul 14 @ 8:53 pm
how did you sort it?
geposted Thu 03 Jul 14 @ 12:19 am
Hello
I'm new to Virtual DJ and video djing. I've just purchased a new laptop with better specs and I'm wondering if you can transfer the downloads from content unlimited in your cache on old laptop to a new one without any problems?
geposted Mon 06 Oct 14 @ 4:59 pm
Why not try it? Then you'll have your answer!
geposted Tue 07 Oct 14 @ 4:37 am
Hi,
of course you can transfer the files. All you have to do is to refresh DRM rights.
geposted Tue 07 Oct 14 @ 6:56 am
