I organized my external hard drive into easy to manage folders. Now all my virtual folders can't find the songs. How do I fix the links?
geposted Sun 29 Jun 14 @ 1:15 pm
did you find a solution... what i did was re-add the parent folder to search database, used the My Library tool to identify the missing files and deleted them.
geposted Sun 29 Jun 14 @ 4:47 pm
Did you move the finals inside Virtual DJ or did you use WindowsExplorer/Finder?
geposted Sun 29 Jun 14 @ 4:49 pm
