Just played with changing text color within VDJ, in one skin only [Blacksheep].
Text changed on all skins {internal 8}. When going back to Blacksheep and changing color
back to original color, it will again changes the color on internal 8.
Even if I change color on internal skin it changes the other skin as well.
Is there a way to revert back to the original skin text color for each skin?
geposted Sat 05 Jul 14 @ 10:31 am
I presume you are changing the color of specific tracks?
In which case, no these changes are part of the tracks XML and will be present in every skin you use.
geposted Sat 05 Jul 14 @ 2:26 pm
Thanks.
Just thought we could revert back since each skin has it's own
text color. I can work around it.
geposted Sun 06 Jul 14 @ 7:42 am
