Topic: AutoGain and Gain (dB) Value
Can somebody tell me an easy way to clear the Tag Values on my files with regards to Gain (dB)?... the database import form from VDJ7 brought values as well as my file tags have Values there.... doing a re-scan of the files will not adjust or override the playback on VDJ8... but... if I manually clear the value of the Gain Tag in the file then rescan with VDJ8 the gain is correct.
VDJ8 wont allow me to select multiple files and delete that tag 'Gain (dB)', I am forced to do it individually, I'm fine with re-scanning my library (had to do that anyways with all my files in VDJ8) but I need to get the gain thing fixed before I do the complete library.
geposted Sat 05 Jul 14 @ 3:08 pm
Select multiple files, open tag editor and change the gain value to 0,00 (or 0.00), apply to all.
