Hi all,
can someone please tell me if it is possible to transfer the saved songs in content unlimited to another laptop as i want to replace my existing one.
geposted Sun 06 Jul 14 @ 7:37 am
Hi,
i suppose you mean content unlimited ?
as far as i know ....yes... this should work....you sould be able to transfer, but only able to playback when cu is active and you are logged in...
geposted Sun 06 Jul 14 @ 10:54 am
Hi , yes that is what I mean ,but can someone tell me how to do it please.
geposted Sun 06 Jul 14 @ 3:10 pm
Easiest way I can see this working is transferring all your music from your old laptop to a USB stick or external hard drive then transferring it all to the same spot it was located on your new one.
If it's in C:\Users\???\Music\ then make sure it all goes back in that same spot but the name after user needs to be the same.
If I'm not mistaken your VDJ library won't miss a beat either
geposted Mon 07 Jul 14 @ 2:19 am
