Topic: GEmini x 2!
Hello, I just received my second Gemini mix table .. I have a Gemini CTRL ONE and now a CTRL SIX
I want to run them at the same time .. But It Seem that they control the same track ?! How can i Seperate them as.. One play on track 1&2 and the Other CTRL Track 3&4 ?!
Thank You ! :)
geposted Mon 07 Jul 14 @ 1:26 pm
For version 7, Config->Mappers tab, select the unit that you wish to control 3,4, ->Mapper options button (right next to the list)->deck assignment
for version 8, config->Controllers tab. Select the unit that you wish to control decks 3,4 ->Deck list
Note. You will need a Pro Infinity license to be able to use both controllers at the same time.
