I decided to tweak some colours...
![](/image/89195/141170/blueskin.jpg)
Now I need a blue browser.
geposted Mon 07 Jul 14 @ 2:52 pm
PMSL - even the songs are "blue"
Blue browser code from EXPO:
<browser>
<pos x="" y="" width="" height=""/>
<colors background="transparent">
<lists background="transparent" stripes="#325561" over="#00FFFF" overstripes="#00FFFF" selected="#0097C9" focus="#0097C9" text="#FFFFFF"
overtext="#000000" selectedtext="#FFFFFF" focustext="#FFFFFF" automix="#999999" livefeedback="#999999"
download="#00FF00" scan="#FFFF00" button="#FF0000" buttonover="#FFFFFF" buttonselected="#FFFFFF" buttonactive="#FFFFFF" insert="#2E2E2E" />
<columns background="#325561" text="WHITE" />
<grids background="#325561" over="#00FFFF" selected="#0097C9" focus="#0097C9" text="#FFFFFF" overtext="#000000"
selectedtext="#FFFFFF" focustext="#FFFFFF" stripes="#0097C9" overstripes="#325561" selectedstripes="#325561" focusstripes="#325561" label="#CCCCCC" />
<toolbars background="#325561" text="#FFFFFF" iconbackground="#0097C9" border="#999999" />
<info background="transparent" stripes="#325561" text="#FFFFFF" label="#5e5e5e" artist="#FFFFFF" title="#FFFFFF" />
</colors>
</browser>
geposted Mon 07 Jul 14 @ 2:58 pm
Sorted.....
![](/image/62337/141171/blueskin2.jpg)
geposted Mon 07 Jul 14 @ 3:18 pm
now add a "S" for Superman and upload as a "limited edition"...;)
geposted Mon 07 Jul 14 @ 4:22 pm
Oh, you mean sort of....
![](/image/55139/141176/blueskin3.jpg)
geposted Mon 07 Jul 14 @ 5:02 pm
yah?...
![](/image/93613/141181/alienware-superman.jpg)
geposted Mon 07 Jul 14 @ 6:37 pm
Ok I see but you still have those stripes on every other track, those are the lines I do not want at all.
geposted Tue 08 Jul 14 @ 3:38 pm
So you just make the stripes the same colour as the background (in this case, as the background is set to be transparent so shows the colour from the png).
Find the hex code for the colour of the darker lines (or the background) and then set the same colour for the stripes.
geposted Tue 08 Jul 14 @ 3:44 pm
It change the stripes to "transparent"
geposted Tue 08 Jul 14 @ 4:56 pm
ok,so how can we change this ?
geposted Tue 08 Jul 14 @ 10:00 pm
You must edit the XML-File of the skin. Look for the Browser section:
<browser toolbar="yes" effects="yes" >
<pos x="9" y="518" width="1422" height="373"/>
<toolbars background="#101010" text="#cbc9c9" iconbackground="#000000" border="#999999" />
<lists background="#2E2E2E" stripes="transparent" over="#B3B3B3" overstripes="#B3B3B3" selected="#000080" focus="#000080" text="#cbc9c9" overtext="#000000" selectedtext="#ffffff" focustext="#ffffff" automix="#999999" livefeedback="#999999" download="#999999" scan="#999999" button="#2E2E2E" buttonover="#2E2E2E" buttonselected="#2E2E2E" buttonactive="#2E2E2E" insert="#2E2E2E" />
Set stripes to transparent.
geposted Wed 09 Jul 14 @ 12:07 am
thank you,but i can not find that section in the xml file,the only browser section i found is this one:
<group name="browser">
<browser>
<size width="1901" height="539"/>
<pos x="9" y="532"/>
</browser>
</group>
</Skin>
ps: i am a mac user
grtz.
geposted Wed 09 Jul 14 @ 2:37 am
What you see is the default browser code. You can add to it by including the extra code.
See the image at the top of this thread (default browser) and then how it changed when I added the code which djtouchdan posted (next pic).
If that's all you want to change, you can strip it down to just:
<colors>
<lists stripes="transparent" />
</colors>
<colors>
</colors>
geposted Wed 09 Jul 14 @ 3:27 am
groovindj wrote :
thnx,What you see is the default browser code. You can add to it by including the extra code.
<colors>
</colors>
<colors>
</colors>
i copy and paste it in to the xml file but still no luck,what am i doing wrong?
sorry for my bad english.
grtz.
geposted Thu 10 Jul 14 @ 12:23 am
Maybe you put it in the wrong location?
Which skin are you using? Maybe your skin has more than one <browser></browser> section, in which case you need to enter the extra code in each section.
If your skin has multiple XML files, make sure you wrote to the correct one!
You should insert the <color> tags in between the <browser> tags, like so:
<browser>
<size etc>
<pos etc>
<colors>
<your choices>
</colors>
</browser>
<browser>
<size etc>
<pos etc>
<colors>
<your choices>
</colors>
</browser>
geposted Thu 10 Jul 14 @ 6:07 am
groovindj wrote :
the skin i use=VirtualDJ 8 FullScreen Browser Maybe you put it in the wrong location?
<browser>
<size etc>
<pos etc>
<colors>
<your choices>
</colors>
</browser>
<browser>
<size etc>
<pos etc>
<colors>
<your choices>
</colors>
</browser>
the only section i found with "browser" is this:
</group>
<pannel id="regbrowser" group="browser" visible="yes">
<browser visibility="not skin_pannel 'fullbrowser'">
<pos x="12" y="560"/>
<size width="1897" height="508"/>
</browser>
</pannel>
<group name="fullbrowser_group">
<menu>
<pos x="1212" y="11"/>
<size width="44" height="26"/>
<off x="447" y="1192"/>
<over x="447" y="1224"/>
<icon x="594" y="1420" height="26" dx="0" dy="0"/>
<tooltip>Browser display</tooltip>
<item text="Regular Browser" action="skin_pannel 'regbrowser' on" check="skin_pannel 'regbrowser'" />
<item text="Full Browser" action="skin_pannel 'fullbrowser' on" check="skin_pannel 'fullbrowser'" />
<item text="Bigger Browser" action="skin_pannel 'bigbrowser' on" check="skin_pannel 'bigbrowser'" />
<!-- <text format="Browser"/> -->
</menu>
<!-- <button action="skin_pannel 'fullbrowser' toggle">
<tooltip>Browser full screen</tooltip>
<on x="447" y="1256"/>
<icon x="506" y="1394" height="26" dx="0" dy="0"/>
</button> -->
<pannel id="fullbrowser" group="browser" visible="no">
<pos x="12" y="47"/>
<size width="1897" height="1021"/>
<browser>
<pos x="+0" y="+0"/>
</browser>
</pannel>
<pannel id="bigbrowser" group="browser" visible="no">
<pos x="12" y="200"/>
<size width="1897" height="868"/>
<down x="11" y="1006"/>
<browser>
<pos x="+0" y="+5"/>
<size width="1897" height="863"/>
</browser>
</pannel>
</group>
</Skin>
if this is any help for you for helping me out?
thank you
grtz paul
geposted Fri 11 Jul 14 @ 12:51 am
Just look for any line that has </browser> and insert the code above it. That should do the trick.
Disclaimer: back up your original before changing anything.
geposted Fri 11 Jul 14 @ 6:25 am
i have tried this but still no luck there,
this is what i have changed:
<browser>
<colors>
</colors>
</browser>
</group>
this is the xml file from the altern 8 skin
i must be missing something here……..
sorry again for the bad englisch
and thank you for your help.
grtz.
geposted Sun 20 Jul 14 @ 7:33 pm
Try this :
<browser>
<colors>
<lists stripes="#202020" />
</colors>
</browser>
</group>
<browser>
<colors>
</colors>
</browser>
</group>
geposted Sun 20 Jul 14 @ 7:44 pm
Fruit wrote :
Try this :
<browser>
<colors>
</colors>
</browser>
</group>
<browser>
<colors>
</colors>
</browser>
</group>
![](/image/89468/142206/Schermafbeelding 2014-07-21 om 03.14.54.png)
![](/image/30651/142207/Schermafbeelding 2014-07-21 om 03.14.41.png)
sorry,but i am still missing something here……………..
geposted Sun 20 Jul 14 @ 8:19 pm
