Started the 20 days free trial of VDJ Pro and the order of the channels on screen have changed, can anyone tell me why and/or how to fix this?
geposted Mon 07 Jul 14 @ 6:55 pm
V7? or V8?
Here's the V8 fix, V7 I'm not sure.
http://tinypic.com/r/155jn9l/8
geposted Tue 08 Jul 14 @ 1:00 am
Yeah its V7 just downloaded the demo for V8 and it works perfect, any other ideas?
geposted Tue 08 Jul 14 @ 9:16 am
Please check which skin you are using in VirtualDJ v7.
Your VirtualDJ LE may have a custom skin created for that controller but when activating the Pro trial, it may have switched to the default v7 skin. The order of the channels on the default 4 deck skin is 1->2->3->4 and cannot be changed unless you use a custom skin. You can still switch back to VirtualDJ LE skin again if you wish by going to CONFIG -> Skins.
In VirtualDJ v8, the default order is 3->1->2->4 which is more common on most hardware. The order can also be optionally changed to 1->2->3->4.
geposted Tue 08 Jul 14 @ 9:20 am
What skin are you using? Some skins have different channel arrangements to others.
Are you using a controller? If so, which one? With some setups, the channel assignments can be reconfigured in the controller mapping.
geposted Tue 08 Jul 14 @ 9:22 am
Using the N4 and yeah it has changed to 1-2-3-4 but i prefer the 3-1-2-4
geposted Tue 08 Jul 14 @ 9:50 am
How do I get a custom skin to change it?
geposted Tue 08 Jul 14 @ 9:51 am
Its sound now I just changed the skin back tar
geposted Tue 08 Jul 14 @ 10:32 am
If you have a LE license then you should be able to register its serial number to your account which should then allow you to download skins from the skins download page: https://virtualdj.com/addons/skins.html
However, you can only use custom skins during the full Pro trial. Alternatively, if you preferred the skin that came with VirtualDJ LE for N4, then you should be able to choose this again via CONFIG -> Skins.
geposted Tue 08 Jul 14 @ 10:33 am
