V7 - I just received a DJ-Tech Dragon Two controller. It include software for VDJ LE. I would like to modify some of the mapping but I am unable to find the map file within the VDJ mapper files. I am a Pro user so I upgraded the LE software to Pro and I still can't find the Dragon Two map. Although it's supported, I do not see any Dragon Two maps listed here on the site. Any idea where I can find or get the map?
I also could not find a definition file for this controller in devices.
Thanks in advance.
Thanks in advance.
geposted Mon 07 Jul 14 @ 10:09 pm
If you launch version 7 with the unit connected, does it work properly ? If yes, then you should see the device in the Mappers tab of CONFIG.
To customize the mapping file, simply choose any of the listed keys, click and then edit the action on the right side.
A mapping.xml file will be generated in the Mappers folder
geposted Tue 08 Jul 14 @ 6:24 am
