Topic: Camara background fixed with latest build!
found out last nite.milkdrops in the background,camara insert in the middle,no black background?..nice one vdj! now it makes sense...
geposted Tue 08 Jul 14 @ 10:37 pm
Can you explain a little deeper how this works?
well first of all...this is for vdj8.then if you have not activated the web cam or any camara with this..my question is,do you know if your camara works at all? does it stream to say other programs like skype?...also you need the full version of vdj.then you look under any of the plugin slots on the panel and open the search menu,scroll down to where it says visualizations.there you will find the camara plugin.click on it to activate it.if you selected milkdrop or plaing a video the camara will be on top.you need to open the Gui (control panels for the plugins ) by clickin on the gui button (if available,some skins have other methods depending on the skin)then tweak the sliders to change the size and tranparency.check that out...
