Hello, I've been using my karaoke songs with VDJ 7 and had no problems ( the formats are mp3 and cdj ) playing them but when I've tried using the same exact files in VDJ 8 I get an error when I try to load any of the decks or any karaoke songs. All songs are unzipped just an fyi
geposted Sat 12 Jul 14 @ 7:46 am
Make sure they are in the right filepath by looking at the file info tab or in browser activate filepath field to check, also you could Highlight your karaoke folder, then right click and "Add to db" .
Good Luck...
Good Luck...
geposted Sat 12 Jul 14 @ 3:54 pm
well they're in the own folder, same place they have always been and look and did what you said and no difference. I don't get it
geposted Sat 12 Jul 14 @ 4:07 pm
Okay, download this codec pack and install, it should help you resolve this in v8.. http://mpc-hc.org/
geposted Sun 13 Jul 14 @ 1:52 pm
VDJ 8 doesn't use external codecs...
geposted Sun 13 Jul 14 @ 2:06 pm
Yes codec download won't help.
If searching can you instead navigate to the folder where you know the tracks to be stored and try loading from there.
If this works then you need to fix the missing DB files.
geposted Sun 13 Jul 14 @ 2:42 pm
Fixed the issue. My files some how had a security permissions altered which prevented VDJ being able to play any karaoke song. Basically I didn't have proper permissions on the files
geposted Sun 13 Jul 14 @ 5:40 pm
How did you change it?
geposted Wed 30 Jul 14 @ 10:27 pm
