Topic: disable midi / hid
Hey everyone
I want to use vdj as a stand alone player but every time I launch it detects my controller even though I hit ignore. How can I disable it reading the Ctrl in vdj8?
In vdj 7 it was easy under the controller tab but I can't find that option in 8 other than ignore.
Thanks.
geposted Sat 12 Jul 14 @ 4:33 pm
options->controllers->disableBuiltlnDefinitions->"yes"
With "ignore" chosen in the mappings, the controller shouldnt work normally. Which controller is the one you work with ?
