I've tried sending my audio output to the bluetooth but there's no sound at all. Speakers out and headphone works fine.
geposted Tue 15 Jul 14 @ 5:37 pm
I have speakers that are blue tooth and use it all the time. Have you turned on the Bluetooth in the laptop? then add the Bluetooth device.. then press the sync button on the Bluetooth speaker. oce it has it , it will link it.. now open virtual dj and go to sound settings select the speaker only select the sound card then test it.
geposted Wed 16 Jul 14 @ 1:42 am
