Hello, I'm using Virtual Dj 7 with skin for 4 decks.
The thing is, use the titler plugin for show the name of the clip, but it only works on deck 1 and 2.
On decks 3 and 4 it does not work.
I wonder if it's some setting or plugin is only for deck 1 and 2 ?
Another thing, would change the color of the yellow band?
There is another plugin that does this, the 4 decks?
thank you.
thank you.
geposted Fri 18 Jul 14 @ 8:12 pm
