Forum: German Forum
Topic: Pioneer DDJ-SB Mapping Update
Zur Info:
Quote :
Mapping files for both version 7 and 8 have been updated.
Version 7.
The unit is not natively supported. An updated version of the mapping files is available at https://virtualdj.com/addons/16489/Pioneer_DDJ-SB.html
ver 1.06
- Fixed erratic Jog behavior when Slip mode is enabled
Version 8
Mapping actions have been updated. You will need software builds ending at .740 or higher (the last 3 digits of the software build indicate the controller's version)
An Operation Guide for version 8 is available here.. https://virtualdj.com/documents/Pioneer%20DDJ-SB%20VirtualDJ%208%20Operation%20Guide.pdf
https://virtualdj.com/forums/191913/Hardware_Technical_Support/_UPDATE__Pioneer_DDJ-SB_Support.html
geposted Thu 24 Jul 14 @ 2:19 pm
