I'm looking into getting a dj setup. A bit about how I mix: I usually have 2 tracks in the mix, and occasionally 3. I like to have a lot of buttons for on the fly cue points and loops. Don't use effects much. Like using eq kills. Don't need jogwheels.
So I'm really after a 3-channel mixer (probably can only find 4), or two 2-channel mixers (not sure if that's possible?), with lots of mappable buttons.
Edit: I probably don't need a crossfader either, as I usually mix with the upfaders.
What do you recommend?
geposted Thu 24 Jul 14 @ 3:41 pm
geposted Thu 24 Jul 14 @ 5:42 pm
Pioneer DJM-5000 It's a 4 Channel mixer but has a three channel sound card (I also have one for studio use and I'm quite happy with it).
geposted Fri 25 Jul 14 @ 12:29 am
