Is there anywhere I can edit info for Most Played? I lost some files and now that they are in a different folder I wonder can I edit the Filepath so my Most Played charts stays the same?
geposted Thu 24 Jul 14 @ 4:49 pm
Do you still have the database entries for the files that moved if so relink them to the new file location inside VDJ (probably the easiest way)
If you got rid of the database entries for these missing files, try to restore the xml to a previous version
If you can't do that, you can fudge the play count in the xml, this is one entry from my xml
You could change the PlayCount to whatever but it would be labour intensive
<Song FilePath="M:\Music\D & B\Jungle\General Waste - Waste Of Time.mp3" FileSize="10462661" Flag="8192">
<Tags Author="General Waste" Title="Waste Of Time" Genre="Calyspso Jungle" Year="2012" Flag="1" />
<Infos SongLength="261.564082" FirstSeen="1399211820" FirstPlay="1399933380" LastPlay="1399933380" PlayCount="1" Bitrate="320" Color="1791940" Cover="34" />
<Comment>Swing and jungle</Comment>
<Scan Version="510" Bpm="0.315805" Volume="1.052242" Key="Bm" Flag="7" />
<Poi Pos="0.050431" Type="beatgrid" />
<Poi Type="automix" Point="realStart" />
<Poi Pos="261.456689" Type="automix" Point="realEnd" />
<Poi Type="automix" Point="fadeStart" />
<Poi Pos="261.178050" Type="automix" Point="fadeEnd" />
<Poi Pos="24.208254" Type="automix" Point="cutStart" />
<Poi Pos="260.892880" Type="automix" Point="cutEnd" />
</Song>
</Song>
geposted Thu 24 Jul 14 @ 7:16 pm
Yeah, if I drag the entries in Most Played into deck I get error. I have new physical files on computer. Just different folder structure. How do I relink them?
geposted Fri 25 Jul 14 @ 3:15 am
V7 oder v8?
Mac or PC?
Mac or PC?
geposted Fri 25 Jul 14 @ 6:30 am
v7 PC
geposted Fri 25 Jul 14 @ 8:08 am
Ah right V7 , my mistake , well open the xml find one of the 'old' entries and change the file path to it's new location
geposted Fri 25 Jul 14 @ 11:59 am
