Topic: Karaoke question.
I don't think this is a bug, it's probably just me. When I play a karaoke file while using the karaoke panel it always goes onto the sidelist after playing. I know about the options removeplayedfromsidelist which I have set as yes but there's no option to remove from karaoke list after playing.
geposted Sun 03 Aug 14 @ 10:00 am
which version of VDJ are you using and what file type are you using? (AVI, CDG, MP4, ect)
I am using the latest version of 8 and it a mixture of .zip, .mp3, .wav files.
that sounds like a bug. depending on if you're using automix or not the song should just leave all of the lists completely. if it's a huge problem you should post in the bug report forum.
Ok thanks, yes it's still doing it and although it's not a major problem the songs get in the way in the sidelist as I have the sidelist quite small.
I got this sorted. A song has to play for about a minute before it is considered "played". I was starting a song and clicking to the end so it went to the codelist.
