Still haven't fix the SHIFT, CTRL and the ALT keys. Keyboard dj's need an update also.
geposted Sun 03 Aug 14 @ 11:52 am
They fixed that in 1900 build, and I've checked all they work. So I think an implied facepalm would be the appropriate jpg right now.
https://virtualdj.com/forums/192138/Beta_Builds_Regression_Bugs/BUILD_1900.html
geposted Sun 03 Aug 14 @ 6:20 pm
Ok locodick rider.....stay in your lane..Even to get updates has bugs...
geposted Mon 04 Aug 14 @ 1:48 pm
No need for the name calling.
geposted Mon 04 Aug 14 @ 1:51 pm
You right..sorry
geposted Mon 04 Aug 14 @ 2:02 pm
Apology accepted.
geposted Mon 04 Aug 14 @ 2:06 pm
Cant seem to get the update..still stuck at 1800 something..
geposted Mon 04 Aug 14 @ 2:08 pm
Exactly what build is it that you're on right now?
geposted Mon 04 Aug 14 @ 2:53 pm
Believe it or not i just did a clean wipe..and suddenly got 1901.751..buttons working fine..I won't complain anymore..Thanks alot
geposted Mon 04 Aug 14 @ 3:29 pm
So excited i forgot to answer your question..i was stuck at 1897.757. Is there a link or a post for the updates when they come out?
geposted Mon 04 Aug 14 @ 3:33 pm
geposted Mon 04 Aug 14 @ 3:42 pm
