Forum: Wishes and new features
Topic: Scripts you'd like to see - Page: 2
effect_active 1 ? returns true when the effect on slot 1 is active. I don't seem to understand your logic here.
effect_select cannot be queried for the moment (always false)
One for a non live scenario [but it might have it's place live too]
If I'm running two monitors with v8 on one and another doing 'windows stuff' I think it would be good if there was a script that fakes a mouse click on v8 to tell the o/s I want that to have v8 as the focus [so keyboard shortcuts work]
This might be a bit niche or perhaps impossible [windows handles that sort of thing] but it's a wish.
Have you considered using AutoHotKey ?
Back to this [forgot to reply]
This one would be a good one to have for VST's and some users could like this for vdj fx too. [cases where fx dial 2 is used more often then fx dial 1]
example one of my vsts has wet and dry on slider 10, while I can can do something like this
effect_active X 'myVST' ? effect_slider X 10 : effect_slider X 1
that isn't as good as
effect_select X 'myVST' ? effect_slider X 10 : effect_slider X 1
Change skins and keep waveform of choice.
I routinely go from the swap 4 decks skin by DJ Dad to the Default skin for the saved loops and other features with a shortcut on the space bar. Every time I do this I lose my chosen wave form of Scratch Wave Form, Left and Right. It goes back to the Default wave form..
I'd love to see a script that allowed me to keep the waveform I was on while I did the swap.
Any thoughts?
The wave type is normally a panel, figure out how to switch panels and call that after you call the skin.
2 selfish ones to make 'routine' better, both maybe useful for other purposes
1 cue_color 'transparent'
this would make the jump markers for routine invisible on the the song pos, and the rhythm wave
2 option, stop cycles cues, add an option to pick the range of cues to cycle, use will type something like this
All
1 - 8
or 1 - 5, 7 - 16 [so the cycle misses cue 6
Another user requested, a script to set browsed_file rating, to go with that why not loaded_song color.
I might have requested before, but it's not in here so, here it is again
could anything that opens a name dialogue [like playlist save or add v folder] take a string param to name what has just been made
playlist_save "playlistName"
I'm on the verge of making a couple of things that a good few people will like.
settings "controllers" should already work
Awesome, so it does.
Well damn, that's a few thousand mouse miles I didn't need to do, XD
thanks for the info.
Anyone under VIP wondering I made a request to shortcut to mappings, which, so I've been told and I've just proved, is already possible, plus another wish.
I quite often raise my requests as there's no doubt in my mind that the other software makers are watching, [I often watch their wish lists]
Is it possible to script some kind of total-time, time-left, time-spend for samples?
Only thing I found is sampler_position, but I don't know how to script this (if it's possible at all).
Would be a nice feature for all Radio-DJ...
Perhaps possible now, not sure, it may need my private plugin to do the math (vdj has limits to the maths it can perform) but I can see how it could work.
I'll look into it, but I think script needs to parse all values, I showed a plugin to devs, but maybe there's a snag to write auto parsing into the script language.
Thanks for your info ;o)
Midi out so I can link my decks with my mates for the project I'm forming & not have to go the Ableton route
Direct MIDI out and MIDI Clock out are already possible.
And this wish doesn't belong to scripting engine anyway! :)
Sorry still finding my feet in this kind of world. I will do more searching as I couldn't find anything useful on it
I also didnt know this... see forums are the best!
djdad wrote :
No actions available to either name/rename/create Sampler Bank or batch-set samples to Sync mode.
Feel free to add all these in the Wishes Forum
21%
