Forum: Wishes and new features
Topic: Scripts you'd like to see - Page: 8
Would love a new script that would allow an "FX loop roll" loop to "move".
(functioning similarly to loop_move of standard loops)
maybe call it FXloop_move
(since the scripts: loop_roll_mode and loop_roll, are already used for a loops with slip)
so FXloop_move +1 would move/adjust the current "loop roll" loop one beat forward.
the "beat" parameter would be most useful.. (illustrated above)
and the "time" parameter, (ms) could be useful, in rarer situations.
+1 on ^that^ one
I'm digging into the sampler and I might be running a few fx on it.
I'm doing something like this to get hold of one of the sampler fx that could be active but out of slot
effect_select_multi "sampler" tapeRecord_aiov & effect_slider sampler 1 0.5
it works but it feels a bit off, eventually some prize winning idiot [ it was me, I was the only entrant, I came second] is going to need to access 2 fx at exactly the same time.
Could deck sampler be a thing? deck -1...
It would unify a good section of script, this intuitive to how everything else works
[not real script]
deck sampler effect_slider tapeRecord_aiov 1 0.5
then there's all the fun of rsi, wait, vars etc etc
scratchbank_load
no param opens a dropdown?
Friendly Bump !
Been wishing/wanting/missing this function for long time.
cue_number num|name newNum, reassign a cue from number or name reference to another number, most desirably to -1 for a marker or [I don't know what char to use...] or to invisible.
small problem with cue_countdown not seeing markers.
Should mapping "Reconnect device", reload the definition?
It's a bit slow mapping how it is now, my definition(s) has 1000's of entries and I'm mapping a bit at a time, most of these encoders are fine in absolute mode [so def'd as sliders] but every so often I need to def one or two as encoders.
Having to restart vdj is killing my flow. [I'm using crash script currently]
loop_save_auto
I've automated the hell out of preparing saved loop for my remix project, but the tedious task open poi editor click one box, open poi editor click again... still exists.
I currently jump into the .xml and do a batch find & replace, but that's going to be a problem when I start using non autoloops [I won't be able to differentiate]
Now with the awesome VDJ 2024, new, shortcuts panel.
It would be great to add to the browser_window so that one could select the shortcuts panel/area.
with for example:
browser_window 'shortcuts'
effect_string_dialog FXNAME STRINGNUM, mostly called when string in fx gui is clicked [or buuton on fx]
set verb works like this set varName < 'nameOfOtherVar'
it could be interesting if there was a new set verb that worked to other way for making arrays, we could do this
set i 0 & set i -1 & repeat_start name 100ms 10 & set i +1 & set varName `THING YOU WANT` & get_text "myArray`get_var i`" & param_cast text & newSet varName
No solid use case yet, but it seems like it would be a simple verb to add, it'll probably come into play for involved scripts with lots of moving parts.
I think I can make this already with virtualfx so I'll see if I can invent a use case.
Used the above in a thing which leads me to next set of wishes
get_string_length
param_cast text `get_var iterator`
get_char_at `stringSource` `get_var iterator`
What I'm hacking my way to is, a tag
that has data
into
sT01 = that
sT02 = has
sT03 = data
And it works! with pad pushing pad, get_text casting to custom_button, and check one char at a time against all possible chars, [well ascii and exclude lowercase] .
Thinking about it now
char_add `get_text or var` `get_int or var` `stringSource`
int being number of times to add so
set_var myVar "a string"
then
set myVar `get_var myVar & char_add "~" 4`
output
a string~~~~
nothing we can't do now but the 33ms between script engine calls of rsi's do add up
param_cast time "%HH:%MM:%SS"
feed it a ms value, it spits out a formatted time string, just one I've run into a few times making things for radio guys who need specialist stuff [like a cue time minus a cue time]
I worked out the reverse of ^1 above, length string to seconds [well any length < an hour]
( Wait 33ms & custom_button 9 ) & ( Get_text "countdown '`get_date %Y`/`get_date %m`/`get_date %d` 00:00:00' & param_cast int & param_multiply -1 & set zero & countdown '`get_date %Y`/`get_date %m`/`get_date %d` 00:`get_browsed_song length`' & param_cast int & set mark & param_add 'get_var zero' 'get_var mark' & param_cast int & set result" & param_cast & custom_button 9 )
instead of hoping custom_button 9 is unused, also getting stuck with an implicit,
something like this
get_text "whatever" & param_cast type_action
An overload of the cycle verb,
no value parameter given, then just increment. I know that sounds kind of stupid, but we can do this to set a dynamic named var to 1
set i 1 & get_text "myDynamicNamedVar`get_var i`" & param_cast & set
so I was thinking
set i 1 & get_text "myDynamicNamedVar`get_var i`" & param_cast & cycle ,
but then you'd want to zero it or decrement or set to another value,
so I suppose it goes back to an earlier idea, >> into set
dynamic_set "VALUE or SCRIPT" "name of thing we want to set"
it wouldn't come in that often but it would save a lot of pain in the times it was needed,
instead of lots of unique vars for similar buttons and changing var1 to var2 several places across several buttons [prone to missing at least 1], you just make a string var for your unique name at the start of the script once.
pad_page_previous
previous pad name held in memory so you can quickly switch back
I can do it with script but it means saving the pad name before the pad switch.
plugin thinking
browser_export 'FULLPATHOFOUTPUT'
dump the browser view to a file so you don't have to take over the browser
or a bit of a change so you can grab details from browser_window songs without needing the focus to be on songs, zero indexed from browser top, and then also a browser_scrollpos that is actually n from top
get_cue prev|next|nearest
or cue_countdown, cue_countup & cue_counter to accept the string "number" as a param to return a number.
I was trying for this and discovered I can't do it reliably with "name", unnamed cues that display the default "Cue 3" can't be accessed with goto_cue "Cue 3".
browser_window_back
just makes browser hijacking easier to hand back in the state it was took over.
I've been doing stuff similar to networkControl, I can see a need/desire for a few more endpoints, [made them myself in my thing]
listbrowser?
listautomix?
all the sideview lists
also a
search? endpoint that takes a script in to search and then returns listbrowser? when browser has done its thing. A local search is so quick you can't detect the `get_status` change to realise it's done, as where online search might be a 1000ms.
I think I just coded 2000ms to make sure.
There's no heartbreak waiting 2s in my case but faster == better right?
84%
