I read the manual but I didn't see where you can add more effects like Flanged LoopOut.
Thanks!
Thanks!
geposted Tue 05 Aug 14 @ 5:22 pm
add fx or 32 bit vst .dlls to
C:\Users\YourPCname\Documents\VirtualDJ\Plugins\SoundEffect
You'll then find them in the effects list
geposted Tue 05 Aug 14 @ 5:25 pm
it doesnt work right, well not on my end, its distorted and has a load click when it deactivates
geposted Tue 05 Aug 14 @ 10:22 pm
Oh yeah LoopOut doesn't play nice with V8
geposted Tue 05 Aug 14 @ 10:46 pm
Hopefully they will fix it soon
geposted Sat 09 Aug 14 @ 9:40 pm
I just been loop the point were I need to stop and fade it out at the same time,it was tricky @ 1st but after practice and practice were the best sound or beat it works.( looping and using the fader down at the same time) not the crossfade.
geposted Sat 09 Aug 14 @ 10:42 pm
Isn't there a synced sweep filter? With a bit of hex trickery you could have both HP & LP, but I'm not sure cos I can't get it.
geposted Sun 10 Aug 14 @ 7:16 pm
I love that effect, but I agree that it doesn't always work right on VDJ8.
geposted Mon 11 Aug 14 @ 7:44 pm
how do I get it though
geposted Wed 19 Nov 14 @ 11:49 am
Sorry buddy but most of the audio fx are only available to pro licence holders, you can however use 32b VSTs.
geposted Wed 19 Nov 14 @ 1:04 pm
