I am having a bit of trouble with the wave bar...to me its not as easy to see each beat with the VDJ 8 version than with the vdj 7. how do i make it more easier to read?
geposted Wed 06 Aug 14 @ 2:19 am
you can adjust it with the little slider in the upper right hand just above the wave window just like in vdj7. then just adjust it til you see the beats
geposted Wed 13 Aug 14 @ 8:42 pm
The adjustments still doesn't make it as easy too read as V7 was. The 'extra gridlines' helps a bit but the 4 beat bars are just too small. It also looks like a fade/shade has been applied to the bars on V8 and honestly we should have an option to remove them.
geposted Sun 17 Aug 14 @ 10:42 am
