Just purchased a Numark edge and I tried to use it with VDJ7 and it wouldn't work.....Any suggestions?
I do have VDJ8 now and it works with that however a deal popped up and said "with your license you can only use the Edge for 10 min"
With the VDJ license I have I assumed it would work a lot longer than that
geposted Fri 08 Aug 14 @ 10:20 am
You have to be on 7.4.1 for the Numark Edge to work
geposted Fri 08 Aug 14 @ 10:37 am
Oh right on thanks
I'll keep using it with VDJ8 though....I've got about a week before my next gig so I'll keep messing with it to get it all figured out
geposted Fri 08 Aug 14 @ 11:11 am
Please ensure that you are logged into VirtualDJ v8 otherwise it will run in Home FREE mode, which will only allow controllers to be tried out for 10 minutes at a time.
You will need an active Internet connection to be able to log in.
geposted Fri 08 Aug 14 @ 12:36 pm
So if I don't have an internet connection I won't be able to use v8?
I hope that's not the case because there have been times where I'm DJing I don't a connection
geposted Fri 08 Aug 14 @ 1:49 pm
Don't worry, you can still use VDJ 8 without a connection.
Once you've logged in and the license file has been created, that file will stay there until you log out again - so if you start up VDJ 8 and it can't find a connection, it'll just read the file and start up as it did previously.
You can also keep a backup copy of that file in a safe place and put it into the directory should you find yourself in a jam.
geposted Fri 08 Aug 14 @ 2:10 pm
Right on sounds good....Thanks
geposted Fri 08 Aug 14 @ 2:15 pm
