Topic: Hercules 4mx Buttons
I have a hercules 4mx black and I noticed that side B that's it's harder to press the buttons while using virtual dj. What could be the cause of this? Side A seems to be fine. Jogwheel lags a little bit also. I'm sure it's something small that can be corrected. I'll take input on what to do to stop this. Thanks in advamce.
geposted Sat 09 Aug 14 @ 8:29 pm
Which version of VirtualDJ? 6, 7 or 8?
Did you try on another computer or with an other VDJ?
Did you upgrade the drivers?
capricepusha wrote :
.. I noticed that side B that's it's harder to press the buttons while using virtual dj. What could be the cause of this? .
What do you mean exactly by this?
