Topic: Pitch Sliders Tempo Mixtrack quad.
Hi guys,
First off, apologies if this is in the wrong place, I'm trying to write this on the sly at work!
I'm using VDJ 8 with my mixtrack quad, complete novice, but getting the hang of it now.
The only thing I'm having slight trouble with is the pitch sliders.
Say the tempo for one song is 124.03bpm another is 126.24bpm.
When I use the slider, is goes from 126.24 straight to 126.01. so When i get it down to near the 124.03, it won't be exactly right, the closest being 123.96 or 124.10.
There is probably something glaringly obvious I'm not doing, but I'm a bit stuck!
is there something I can do to change the parimeters so it adust at 0.01bpm at a time?
Thank you in advance!
Brian
geposted Wed 13 Aug 14 @ 7:12 am
What is your pitchrange set to? If it's too high then it's possible that the smallest step is too big.
Another reason could be that the resolution of the pitchslider hardware itself is just too rough.
I played around with the range a while ago from 10% up to 100%, but I'll certainly give it a shot to see if it makes a difference.
As far as I can remember the on screen sliders 'skipped' the same amountm but again I'll play around to see if it resolves it.
Thanks for your help man!
I set my pitch range at 6 on my Numark N4. or I get as close as i can, then I hit sync.
If you dont want to use sync keep nudging the jog wheels
