Hello
First sorry for my english. Im from germany, but in the german section I got no response.
A friend has problems to map the PLAY/PAUSE button on his Hercules MK4 in VDJ7 and asked me for help. Everything else works fine.
When I map "play" to the button, the music starts.
When I map "stop" to the button, the music stops.
BUT when I map "play_pause" to the button (that is what I want) the music "starts" for a very, very short moment, and stops right away.
play_pause should chang the state from play to pause or from pause to play, or not?
Where is my mistake?
geposted Thu 14 Aug 14 @ 10:51 am
I have this very same problem.. If you map it to Play_Pause the button does nothing but if you map it to one or the other it works... I have sent a ticket question to this problem but have not been replied to yet... because of this , it makes it unusable as you can't pause it... or am i missing something??
geposted Sat 13 Sep 14 @ 8:38 am
tengo el mismo problema, alguien puede ayudar?
geposted Sat 19 Mar 16 @ 3:48 pm
This is an English speaking forum, please try one of our other forums, with a language that you may understand better. try here.
geposted Mon 21 Mar 16 @ 4:13 am
