can any one tell me how to change the channel order on the above controller ?
It's currently set on 3-1-2-4
I would like to change this to 1-2-3-4 if I can ?
I have tried to change this in the controller settings within VDJ 8 but it is not changing it ?
Any help or ideas would be welcome, Thanks in advance
geposted Fri 15 Aug 14 @ 7:04 am
This is based on the Skin. Are you using the default skin within VDJ8?
(On the 4 deck default skin, there's a small button above the crossfader. If you click that, you should see a bunch of different options.)
geposted Fri 15 Aug 14 @ 9:42 am
