Topic: Lower Autogain Settings in 7.4.1
I am using autogain to set the level of my playlist.
I have it on auto, and I don't want to touch the gain knobs so all the songs play at the same level.
The system is doing it without any problem, but on my pfl meters, i often see the sound touching the red led, with all the orange leds on.
If I was controling the gain manually, I would set it a bit lower, so it dosen't even touch the red, wich is where it starts distortion.
As I can set the final volume that we hear on the speakers using the main volume knob, Is there a way to set the "normal" volume of autogain to be a bit lower?
Thanks
Zorza
geposted Fri 15 Aug 14 @ 9:01 am
Adjust headroom to 2db I think that will get it
