I've got the atom-based tablet pc with windows 7 set up on it. My "old" tower pc also runs windows 7, and they are interconnected via wi-fi. The hi-fi audio system is connected to the tower pc. My idea is to use the tablet for djing, in the way that master signal is transferred to the tower pc via wi-fi and then played via the hi-fi system, and the audio output of the tablet is used for headphones. Is VirtualDJ suitable for it, and will I need additional software for transferring sound from tablet to pc to its RCA outs ?
geposted Sat 23 Aug 14 @ 3:52 am
It's the 1st time I write here, maybe I had to post this in "PC Version Technical Support", but I can't ask for support, because I just look over to find the software that will best suit my idea, and I had no problems running VDJ on my old pc alone, while I used the PCI audiocard for main out, and the motherboard out for phones.
geposted Sat 23 Aug 14 @ 4:15 am
Why you making life more complicated than it needs to be? Get a controller and be done with it.
geposted Fri 14 Nov 14 @ 1:12 pm
