Using VDJ version 8 on mac edition.
Today, I tried the automix function, and saw that when mixing from one song to the other, VDJ was increasing or decreasing the BPM during 3 or 4 seconds in order to make the transiton even smoother than just the fader. It was realy clever I thought!!
Then, it just stoped doing that and now it is just doing the fader without any bpm adjustment.
Does anyone else have the same problem? Automix is in smart mode.
Thanks
Zorza
Thanks
Zorza
geposted Sun 24 Aug 14 @ 3:03 pm
Hi,
automix can ajust only in a certain bpm range. so if there are tracks e.g. to be mixed from 125 to 128 bpm there should be no problem.
if you have a 89 to 132 bpm guess the automatic ajustment does not work.
also depends on the max pitch range you have set on each deck
greetz
rob
greetz
rob
geposted Wed 27 Aug 14 @ 1:39 am
