I just bought a denonmc3000. i run vdj8 on windows 7. my mapping issue is that the left jogwheel is unresponsive when a track is playing. it becomes responsive when the track is stopped so obvs its not the hardware and therefore im assuming its a mapping issue and im wondering how i fix this. ive never done any controller mapping before and am apprehensive about tinkering with it on my own lest i accidentally mess something up in the process.
geposted Mon 25 Aug 14 @ 1:52 pm
This may be because the jogwheel is in CD mode. This will cause the jogwheel to speed up/slow down the song when it's playing instead of scratch.
Press the VINYL button on the appropriate deck to toggle it between vinyl (scratch) and CD mode.
geposted Wed 27 Aug 14 @ 7:15 am
bonjour j ai probleme de mappeur pour le denon mc 3000 sur virtual dj 7 et virtual dj 8 pro pouvez vous me le procurez merci d avance
geposted Mon 01 Aug 16 @ 11:34 am
bonjour mon cross-fader est le seul a ne pas fonctionner sur le virtual dj 7 pro et virtual DJ 8 pro reste figer mon contrôleur est denon mc 3000 mon system Windows 10 et j ai les deux virtual installer le 7 et le 8 qui jusqu’à maintenant fonctionne a part le cross-fader qui ne va ni a droite et ni a gauche pouvez vous m aider svp urgent
geposted Mon 01 Aug 16 @ 12:56 pm
I had a starting crossfader error which I could work around in win 7, after upgrading to win 10 it disappeared. Sometimes the crossfader would work straight away, other times I had to restart, even more than once on some occasions.
The other thing is I had a temperamental left hand start button, and I was thinking of replacing the tact switch.
Anyway under win 10 there seems to be no problem?????
hello my cross-fader is the only one not run on virtual dj 7 pro and virtual DJ 8 pro remains fix my controller Denon mc 3000 my system Windows 10 and I have both virtual install 7 and 8, which until now works in a hand the cross-fader which will neither right nor left can you help me please urgently
As I said all I could do to get the crossfader working was to be extremely careful with the startup sequence. Hence the controller was plugged in and switched on prior to starting vdj 8.
geposted Mon 01 Aug 16 @ 1:58 pm
bonjour comment configurer ma zone video lorsque je mixe en video la relecture video enregistre joue au ralentie au lieu du normal de l enregistrement en direct merci de vouloir m aider a parametrer le virtual dj 8 completement afin que je ne puisse pas avoir de bug
geposted Sun 07 Aug 16 @ 6:47 pm
Please either post in English or use the French forum area.
geposted Sun 07 Aug 16 @ 7:23 pm
bonjour
je suis entrain d installer un controller Pioneer ddj- sx2 sous virtual DJ 8 et j’ai un problème de mapper qui fais que aucun élément ne fonctionne disons pas de reconnaissance du controller pouvez vous m aider avant ce weekend je suis sous Windows 10 x 64 bits
geposted Thu 18 Aug 16 @ 10:49 pm
s'il vous plait essayer notre forum francais isi je vous remercie.
geposted Mon 22 Aug 16 @ 9:53 pm
Hola!! tengo un problema con mi denon mc3000 de repente ya no me reconoce el midi ni con la version 7.4 u 8
los auixiliares me funcionan y tengo salidade audio en la ganancia y audifonos pero el controlador no responde.
Hay mapping??
Alguien que me pueda auxiliar???
Hay mapping??
geposted Sun 01 Jul 18 @ 7:19 am
Por favor, prueba nuestro foro de Espanol ubicado aqui.
Locked by AMAHM
Locked by AMAHM
geposted Tue 03 Jul 18 @ 1:32 am
