Cant wait to try this out, http://www.reloop.com/reloop-neon
Might ditch the DDJ SP1 for a couple of these. Hopefully the VDJ mapping is on par........
geposted Mon 01 Sep 14 @ 6:49 pm
8 pressure pads 12 buttons & 2 encoders, and some tri-colour Leds. Not much clever about that, (about as smart as a PS2 pad as far as I figure) the packaging looks nice though I might steal the design.
I suppose the I2C link is a smartish idea. Although only linking two is wasteful.
You'd rather these than a DDJ SP1 are you mad? I'd gladly forget about pretty lights for 7 dials.
geposted Mon 01 Sep 14 @ 7:20 pm
Has more function the SP1 with the exception of the effects knobs and library controls..... The library controls I have on any I my mixers expect on my Pioneer DJM 800 so no lose to me there. As for effects, well I don't use any of VDJ's audio effects because in my opinion are not up to par. Video effects are all I would use and even then VDJ is lacking there as well, again my opinion.....
The mapping we have for the SP1 needs some work, example, when setting an auto loop I have to use 2 hands!!
I'll just have to wait and see when it comes out.......
geposted Mon 01 Sep 14 @ 7:40 pm
It can't have more functions (certainly not with VDJ), it has less buttons, Although it sounds like the DDJ SP1 mapping isn't the best.
geposted Mon 01 Sep 14 @ 8:32 pm
For about $200 US, it's a pretty good deal. I might pick one up and ditch my Korg Nanopad, which I use now for loops and effects when playing on TCV.
geposted Tue 02 Sep 14 @ 11:55 am
Why is that ? There is a LOOP encoder to choose the desired length and push to trigger.. so i would say just 2 fingers not 2 hands hehe
geposted Tue 02 Sep 14 @ 5:49 pm
Doesn't work on mine, never has now that I think about it. I can scroll through the loops but when I push down nothing happens, never has worked right.
So I have to hold shift and press auto loop otherwise loop roll which has its own problems (2 hands or hand stretched out), now if I hit the pad itll loop but once I release the pad the loop turns off. The only way to turn a auto loop on is with 1 hand hold shift then press a pad (1,2,4, 8 etc) with the other hand!!
So its either use 1 hand with fingers out stretched or use 2 hands which isn't very practical at all...............and if you need a video Ill upload one tomorrow cause the mapping is not right, hehe...............
geposted Tue 02 Sep 14 @ 5:51 pm
then maybe your unit is switched to Serato mode. Switch to the "Other DJ application" (or vice versa ..cant recall .. :(
geposted Tue 02 Sep 14 @ 6:08 pm
There is no switching to Serato mode?? The only switch on the thing is to dim the lights.
RTFM (UTILITIES) lol [djdad]
Let me dig this thing out cause it didn't install any utilites.................BRB
Well I looked at the manual and it says "For details, see your dj softwares operating instructions"
So what mode is it supposed to be in, A,B,C,D,E,F,G or H
Edit, ok its working but the mapping is still wrong, Why do we have "Loops Temp" when the unit says "Auto loop"??
Good. Since there is already a way to trigger Auto Loops (using the encoder), we thought that Temp Loops would be useful..Anyways i am sure for units like that, if you ask 100 users , you will get 100 different mapping layouts. Please open a new thread if you want to propose any changes for the mapping. [djdad]
geposted Tue 02 Sep 14 @ 6:11 pm
