Topic: VDJ 8 Question - Song Not Loading
Hi,
I have this song on my computer - I was wondering if I want you to by Weezer.
It shows up twice in the search.
When I try to load one, it throws an error, when I load the other, it loads properly.
How can I solve that?
geposted Sat 06 Sep 14 @ 9:20 am
have you try with windows media player to see if it's not the file wich have a pb
Clean your database. In theory that should remove any broken links (if that's the issue).
Check the tag editor to see if the file is there or not.
