When will there be a Pioneer DDJ-SX2 Mapper???
geposted Tue 23 Sep 14 @ 7:28 am
geposted Tue 23 Sep 14 @ 7:32 am
Still, there is no SKIN for the Pioneer DDJ-SX2,
I got the mapper but not everything works with the SKIN of SX1! I'm not the only one, when is it going to be released???
geposted Thu 12 Mar 15 @ 5:45 am
hi thea how do I get the mapping for virtual dj 8 pls
geposted Wed 15 Apr 15 @ 4:30 am
ddj sx 2 mapping for virtual dj
geposted Thu 16 Apr 15 @ 2:05 am
no mapping required, it's built in.
geposted Thu 16 Apr 15 @ 2:19 am
yes it's native to VDJ8 and works great. I'd like to see a mapper for vdj7 though. for those times i need to use it
geposted Mon 20 Apr 15 @ 11:04 am
i gor vdj 8 and i hooked it up with ddj sx2 but nothing happens evntho i can see the sound card of ddj sx2. any help with screen shot showing the configuration?
thanks
thanks
geposted Fri 24 Apr 15 @ 6:58 am
Please make sure that you have the latest drivers for the SX installed.
Home Free Version will support your controller only 10 min after each launch of VirtualDJ
geposted Fri 24 Apr 15 @ 8:59 am
Hi guys!
Is there a way to use SX2 as an external mixer using VDJ8 as a player without the internal mixer
With th DNMC6000 it's very easy, but I don't find any solution for the piopio
Furthermore, I get pb with the internal mixer:I can't apply Hi, MID & Low in the headphones
geposted Fri 01 May 15 @ 4:20 pm
To get EQ on Headphones, goto Settings (Config)-->OPTIONS and change the setting EqInHeadphones to Yes (if not set already)
geposted Fri 01 May 15 @ 5:48 pm
Also, it's not possible to use SX2 as an external mixer without using a second soundcard.
That's a limitation of the hardware of SX2.
It was the same case on original SX as well.
The sound of the built-in soundcard is routed directly on master and headphones output of the unit.
geposted Sat 02 May 15 @ 11:29 am
I need assistance in downloading mappers for Pioneer DDJ SX2
geposted Fri 10 Jul 15 @ 4:20 am
Just register you VirtualDJ Infinity (or controller, or subscription) copy download it form the download center.
But I think, a built-in mapper should be available too.
geposted Fri 10 Jul 15 @ 4:22 am
hello i am looking for the mapper in the pioneer ddjsx2
if anyone have it that
will be a great help please
email me on
--- removed --
thanks
Moderator : Posting contact information is not permitted by No-Licensed Users as per our Forum rules
email me on
--- removed --
thanks
geposted Sun 10 Jul 16 @ 1:32 am
need help pls!!!
i havd a pioneer ddj sx2.... it is nit showing up as a sound card...how do i solve this?
geposted Mon 03 Apr 17 @ 9:39 am
@1aaliyah
install the drivers that came with the unit.
https://www.pioneerdj.com/en-us/product/controller/ddj-sx2/black/support/#info
geposted Mon 03 Apr 17 @ 10:06 am
Even if it did, you won't be able to use it with VDJ 7. New controllers are only added to VDJ 8.
VDJ 7 is dead.
geposted Mon 03 Apr 17 @ 4:47 pm
Hello . I need the mapper for vdj 7 with ddj sx2. Vdj 8 is crap with all those limiters
geposted Tue 18 Apr 17 @ 8:10 pm
There isn't a mapper for VDJ 7. If you really want to use the SX2 with VDJ 7, you'll have to create your own definition and mapping files.
The limiter(s) in VDJ 8 only become a problem if you push your levels too much. They exist to protect your equipment from overload. Don't run in the red and you won't have any issues.
geposted Tue 18 Apr 17 @ 8:22 pm
