Topic: Uninstall VDJ8 and reintall
How do I uninstall VDJ8 and reinstall it but I don't wanna lose the setting I already have setup.
geposted Thu 25 Sep 14 @ 10:17 am
if you want to keep the settings only, make a backup of your settings.xml in the vdj root folder just to be sure.
When uninstalling v8 you will be asked to delete database and setttings...so you can also choose "no" there
Thanks, that exactly what I thought and did. I had to make a test to see if I put a clean install it wouldn't freeze when shutting down. It started freezing when 1960 was updated on my test computer. It's doing the same thing again. It never froze on exit before 1960 update
