The subject has been brought up before but things change,
Currently I backup to an external and all I do is (hope for the best) delete everything on the external and copy everything (from internal) across
But I'm just about hitting my internal limit, so I need to get smart.
What sync software would you recommend, paid for or freeware?
I've read that windows has robocopy built in but command line stuff can be a bit, well scary when new to it and dealing with precious tunes (most of which are CC but still)
geposted Sat 27 Sep 14 @ 3:40 pm
i'm using syncback free has pretty much all the bells and whistles of the paid stuff
http://www.2brightsparks.com/
i just wish they would integrate something into vdj that would transfer a playlist with a database to a folder on a removable for easy on the go djing
geposted Sat 27 Sep 14 @ 5:12 pm
geposted Sat 27 Sep 14 @ 5:21 pm
You mention robocopy - why not use it?
robocopy <Source> <Destination> [<File>[ ...]] [<Options>]
ROBOCOPY C:\locodog\Music E:\Music /COPYALL
Put the command inside a text file and give a "bat"extension - save on your desktop -finished..
geposted Sun 28 Sep 14 @ 12:39 am
I second Syncback!! I have been using it for years.
geposted Sun 28 Sep 14 @ 9:13 pm
geposted Mon 29 Sep 14 @ 3:14 am
