Hey anybody think they can come up with some good scratch plugins
maybe something like a scratch that DJ SY (Hardcore DJ) might do.
Thanks In Advance
Thanks In Advance
geposted Mon 29 Sep 03 @ 8:18 pm
yeah this would be nice...
atomixmp3 has some cool scratch effects
from DJ corpse and co
like baby scratch
or stab scratch
i'll like to convert them to VDJ...
Monty
like baby scratch
or stab scratch
Monty
geposted Mon 29 Sep 03 @ 10:21 pm
hey for real ,,,,,,,, what happened to dj corpse ????
hey use to make some nice effects
specially the quadrophonic flanger ,,,,
we would really like to c his effects on vdj
dj smokey
dj smokey
geposted Wed 10 Mar 04 @ 7:02 am
He gave up the DJ scene last time i spoje to him :(
geposted Thu 11 Mar 04 @ 10:45 pm
too bad that guy was good
and i'm guessing he's a programer right walkers?
geposted Mon 15 Mar 04 @ 9:28 am
cant remember to be honest! havent spoke to him for a long time now!
geposted Mon 15 Mar 04 @ 10:11 pm
i was thinking the same thing a few days ago. there are alot of good plugins for AtomixMP3 that are not avaliable for VirtualDJ.
would it be possible for someone on the team to contact Dj Corpse and get his source codes for the original plugins so that they can be ported for use in VDJ.
geposted Tue 16 Mar 04 @ 2:43 pm
I tried to contact him to do this but had no answers until now :(
Nevertheless, I am not sure VDJ needs scratch "effects" as you can do real scratch with it.
geposted Wed 17 Mar 04 @ 8:07 am
ur propably right
but i think it wouldnt be that hard converting the effects and some of the effect where really good i would mind having them in vdj at all
dj smokey
dj smokey
geposted Wed 17 Mar 04 @ 9:28 am
when i was talking about effects before, i wasn't just meaning scratch effects. there are heaps of great effects for atomix that are not avaliable and or do not sound asgood in virtualdj. take the cut effect for example, i loved this effect in atomix but it is now next to imposible to make it sound any good in vdj
geposted Fri 19 Mar 04 @ 11:41 pm
I'm agree with you, djzero. There are many effects like Adjustable AutoWah, Different cuts, QuickPan Effect and Adjustable Linear Sawtooth Flanger that works and sounds great when you use it.. Maybe it is nessesary to convert them to VDJ software..
geposted Tue 23 Mar 04 @ 6:12 pm
Most of the effects are not made by the virtualdj team. They are made and submitted by users. If you think of somthing that you would like, make it and submit it.
geposted Tue 23 Mar 04 @ 7:54 pm
I was wondering if there are any tutorials about creating your own plugins for VDJ instead of waiting for others to create more plugins?
geposted Thu 08 Apr 04 @ 9:37 am
You can find some sample files here:
https://virtualdj.com/support/developers/effects.html
If you can read french, I wrote some explanation here:
http://www.atomixfr.com/developpement/plugin/
If you cannot, try this translation:
http://translate.google.com/translate?u=http://www.atomixfr.com/developpement/plugin/&langpair=fr%7Cen&hl=fr&ie=UTF-8&oe=UTF-8&prev=%2Flanguage_tools
I hope this help you.
If you have questions... maybe I can answer :)
geposted Thu 08 Apr 04 @ 8:12 pm
hehe. phew.. i took a look at those urls.
i know a little 'basic' but C++ is far beyond my capabilities :(
i'll just have to wait for someone who writes a good reverb-plugin.
geposted Wed 21 Apr 04 @ 10:59 am
Yes,
Now ALL old Atomix scratch plugins like baby scratch,... from DJ corpse can be used with the new version V.1.09. This version is compatible with the older atomixmp3 plugins.
Monty
Monty
geposted Tue 27 Apr 04 @ 5:45 pm
Cannonball...
U know, VDJ has VST plugin possibilities :)
So, there are plenty of good reverb plugins out there :)
Here is a good free one:
http://www.pspaudioware.com/
(". It generates reverberation using twelve string operators with adjustable damping and decay time")
and there are plenty of others :)
Go to VST forum here at VDJ - you might find one there that you might like
Dj in norway
Dj in norway
geposted Tue 15 Jun 04 @ 8:25 pm
