Hi , can anyone help with the commands when starting virtuadj to make it start with multi mode effects selected instead of single mode and also to make it save the selected effects when closing and re-opening the program
I'm just learning about the commands available but have no clue with this one
thanks
thanks
geposted Thu 02 Oct 14 @ 9:25 am
what skin do you use?
geposted Thu 02 Oct 14 @ 10:47 am
Hi, I use the standard vdj 8 skin
geposted Thu 02 Oct 14 @ 10:58 am
there isn't this funct on the skin standard
geposted Thu 02 Oct 14 @ 11:19 am
If you mean the 4 decks skin, then the action for the ONINIT key of your keyboard or controller should be ..
set '$fx1multi' 1 & set '$fx2multi' 1
for the 2 decks skin, software will display the last used panel, but you can still force the 3 FX slots one if you use ..
skin_panel 'sidebar_left_fx' on & skin_panel 'sidebar_right_fx' on
geposted Thu 02 Oct 14 @ 5:03 pm
