Hi there.
Anyone knows when the effect "Flanged Loop Out" as VDJ7 is available for VDJ8?
Would appreciate an answer thanks.
geposted Fri 03 Oct 14 @ 6:11 am
Why not just use the loop out effect and then apply the flanger effect to that?
geposted Fri 03 Oct 14 @ 7:20 am
If I recall, that effect works under VDJ8
geposted Mon 06 Oct 14 @ 2:48 pm
@ musicbox
i can confirm that the effect will work with V8
geposted Tue 07 Oct 14 @ 12:59 am
Real? - What should I do with it exactly the effect also works at VDJ8.
These are referred to as "Flanged Loop Out":
https://virtualdj.com/addons/449/Flanged_LoopOut.html
geposted Fri 10 Oct 14 @ 3:59 am
With VDJ-8 trying to loop out effect hit the effect then use the Roll Out ( best one/sound on the pad ) & volume down or do a loop beat with volume down.
geposted Sun 16 Nov 14 @ 6:51 pm
RobRoy wrote :
@ musicbox
Please tell me how
geposted Wed 12 Aug 15 @ 5:57 am
Just install it.
It's working here too.
What are your problems?
geposted Wed 12 Aug 15 @ 8:42 am
This effect does not work properly on VDJ8. No fading out.
geposted Mon 17 Aug 15 @ 3:32 am
musicox wrote :
Hi there.
geposted Thu 07 Jun 18 @ 3:35 am
I think I'm still using my old v7 one in v8 - and it seems to work ok:
geposted Thu 07 Jun 18 @ 3:47 pm
