First post and kind of a newbie at DJ:ing, so bear with me.
Anyone use the Traktor Audio 2 Mk2 USB soundcard with Virtual DJ? Thinking of buying this one and only want someone to confirm that it works.
https://store.djtechtools.com/products/traktor-audio-2-dj
Thx!
Thx!
geposted Sat 04 Oct 14 @ 7:44 am
It will indeed work :)
geposted Sun 05 Oct 14 @ 8:42 am
Hi Guys
With the Audio 2 soundcard how do I split channels correctly so main is deck 1 and headphones are in deck 2 ?
Thanks in advance.
Thanks in advance.
geposted Tue 09 Dec 14 @ 1:53 pm
Had the same problem as above. Set up as explained by vdj but still sound comes down both channels (main & headphone) from deck 1 and no sound on deck 2. using vdj v8 please can anyone help...
geposted Sat 13 Dec 14 @ 9:19 am
ecco la configurazione per avere sia il master che il preascolto. scaricate pero' i driver traktor dal sito...
geposted Thu 18 Dec 14 @ 8:07 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the correct language forum: https://virtualdj.com/forums/8/Italian_Forum.html
geposted Thu 18 Dec 14 @ 9:58 am
I use this sound card.
In Sound Config/Advance, For MASTER: select ASIO and set it to channel 1/2
HEADPHOINES select ASIO and set channel 3/4
Make sure you install the ASIO Driver that came with unit or download the newest one.
geposted Mon 22 Dec 14 @ 8:33 pm
