Topic: Gobo Projector
What are you guys using for a gobo projector? I'm looking for something not too expensive that I can use for weddings and corporate events. Doesn't have to be anything too fancy. Just something that projects a pattern on the dance floor a few feet in front on where I would be DJing.
geposted Mon 06 Oct 14 @ 8:07 am
You'll want something more than rated at 10w to be worth while to you.
Use an old projector - make any message or photo and project onto walls floor etc. Cheap easy and can change the image.
Yep you can get some great results with a projector but it's all down to the strength of the unit your using eg lumens and the throw distance.
I use the Chauvet gobo zoom.
It comes with a bunch of useful gobos and colour filters. Can be set with or without dmx.
