Topic: Wrong LED lights up
I have this code set on one of the pads of my Gemini G4V --
var '$issamplerleft' ? var_equal 'sampleBankLeft' 0 ? sampler 1 play_stop & sampler 1 select : var_equal 'sampleBankLeft' 1 ? sampler 5 play_stop & sampler 5 select : var_equal 'sampleBankLeft' 2 ? sampler 9 play_stop & sampler 9 select : nothing : var '$ishotcueleft' ? deck left hot_cue 1 : var '$isautoloopleft' ? deck left loop 4 : var '$ismanualloopleft' ? deck left loop_in : var '$islooprollleft' ? deck left loop_roll 0.125 while_pressed : nothing
It works how I want it to, but it lights up the wrong LED pad. I changed it from
var '$isautoloopleft' ? deck left loop 0.125 (default)
to
So whenever I press the pad, it doesn't light up the pad that I pressed but instead the default that it was set to. Any way I can tell it to light up the right pad and not light up the other one?
geposted Sat 11 Oct 14 @ 6:18 pm
You shouldnt use the version 7 mapping for version 8. The files you will probably find in the Gemini website are for version 7 and those are not required for the unit to operate with version 8.
anyways, for your issue, you will need to also edit the action for the LED_BTN(X) accordingly
I'm using VDJ7. And how do I edit the action of each LED button like you were saying?
I dont see how your Subscription License can allow you to use the Gemini with version 7..
Anyways...
you changed ..
to
for the button, so the same action needs to be changed to the LED_BTN(x) where x is the number of the button you changed..
Most likely, this was the BUTN1_LEFT, so you will need to locate the key named as .. LED_BUTN1_LEFT and make the same change as above.
